![imx519 offer the best price performance ratio in embedded cameras](https://www.arducam.com/wp-content/uploads/2021/11/imx519-offer-the-best-price-performance-ratio-in-embedded-cameras.jpg)
Up The Camera Game for Raspberry Pi
We look to help the industry build low-cost embedded camera systems for hundreds of real-world applications.
2 times higher resolution than the v2 camera, 40% higher than the HQ camera. Based on the 16MP Sony IMX519 sensor, this new camera module gives all Raspberry Pi hackers every bit of power they need to build future-proof projects.
The community has been craving autofocus in Pi cameras, so we took the advice. We gave this camera the classic V1/V2 form factor so you can add hassle-free upgrades to your existing projects. Also, we adapted PDAF for 16MP Camera recently which will greatly improve the focusing speed.
It’s not just the resolution bump, the “quality” is way higher than the HQ Camera too. With the same camera tuning algorithms from the foundation, this module beats the Raspberry Pi HQ camera in every aspect. (sharpness/saturation/exposure/etc.)
Less for us, more for you. We want it to help push the Raspberry Pi and embedded ML/MV forward, everything about this camera will be truly open source.
Get a huge performance boost without spending more. 25 US dollars ($50 for a lensless HQ module), 16 megapixels (8MP for the V2 module), and with dozens of new features, we expect it to take the 4th spot after the V1, V2 and HQ camera.
Arducam Autofocus Camera | Camera Module V2 | HQ Camera | |
Net Price | $25 | $25 | $50 (without lens) |
Sensor | Sony IMX519 | Sony IMX219 | Sony IMX477 |
Optical Size | Type 1/2.53″ | Type 1/4″ | Type 1/2.3″ |
Sensor Resolution | 4656×3496 pixels | 3280 × 2464 pixels | 4056 x 3040 pixels |
Still Resolution | 16 Megapixels | 8 Megapixels | 12.3 Megapixels |
Camera Case | Yes | No | No |
Focus | Auto | Fixed | Manual |
Video Modes | 1080p30, 720p60 | 1080p30, 720p60 and 640 × 480p60/90 | 1080p30, 720p60 and 640 × 480p60/90 |
Linux integration | V4L2 driver available | V4L2 driver available | V4L2 driver available |
Focal ratio (F-Stop) | 1.75 | 2.0 | Depends on lens |
Focal length | 4.28 mm | 3.04 mm | Depends on lens |
Any Pi model that has a MIPI connector can use this camera.
No, you can not remove the IR-CUT filter. We have the NoIR version planned.
The camera has a 7.103 mm (1/2.534″) diagonal image size, it’s also a back-side illuminated sensor, just like the Raspberry Pi HQ camera.
There’re the video modes you can get with Raspberry Pi:
You can capture 4656×3496 still images. But for video, it’s impossible with a Raspberry Pi.
The camera itself is capable of capturing 4K@30fps video, but the Pi is the bottleneck.
Yes, it supports SME-HDR with equivalent full pixels.
The closest you can get is 10cm. The focus range of this camera: 10cm ~ ∞.
The lens on this camera has an 80° viewing angle.
200 seconds.
Yes. We gave it the same board design and is compatible with any camera enclosures that work with V1 or V2.
You can turn it into a high-resolution webcam with any Raspberry Pi, there’re plenty of tutorials you can follow.
And If you want to use only the camera module as a webcam (UVC-compliant), we have the Raspberry Pi High Quality camera available here.
With a bit of modification, yes. We have seen many astrophotography projects with the official Pi cameras, you can follow the same instructions.
Support for Nvidia Jetson Nano/Xavier NX boards is still in the works.
However, with the help of our USB 3 camera dev kit, you can use this camera, or any of the official (V1, V2, HQ) cameras on any platform you want.
300mm FPC cables can still work. If you want the cable to be longer, use it with our CSI-to-HDMI adapter.
Yes, you can use it with our CSI-to-HDMI connector for longer cable lengths.
Yes, we have stereo camera kits planned, and you can use this camera with our multiplexers too.
