The second generation of Arducam USB2.0 shield is designed to replace the old one released on March 2017 while keeping the same form of factor and software compatible. The highlight of the new USB2.0 camera shield is that it has onboard 8MByte hardware frame buffer, and overcome the bandwidth and dropping frames issue when using the software frame buffer scheme. In addition, with onboard frame buffer it supports synchronized multiple cameras taking images exactly at the same time. Now it well supports both PC and embedded system like Raspberry Pi, and also can provide customized support for Odroid, Beaglebone Black, Nvidia JETSON TK/TX boards.
  • Support any parallel image sensors
  • Support 8/10/12 bit pixel color depth
  • Build-in IRCUT control  (optional)
  • Need extra MIPI to parallel adapter board for supporting MIPI interface sensors
  • Support x86 PC, ARM 32/64bit, Odroid C2, Raspberry Pi hardware platforms
  • Support Windows, Linux OS, ROS
  • Support C/C++, Python Programming Languages
  • Bandwidth:480Mbps USB2.0
  • I/O Voltage Standard: 3.3V
  • Connector: Micro-USB2.0
  • Onboard Frame Buffer 8MBytes
  • Size: 40 x 40 mm
  • Weight: 20g
  • Power Consumption: 5V/300mA
Table 1 Featured Parallel Camera Modules Supported
Resolution Frame RateCamera ModuleSensor Vendor
0.3MP30fpsOV7670/OV7725/OV7740Omnivision
0.3MP30fpsGC0308GlaxyCore
0.3MP60fpsMT9V022/MT9V034Aptina
1MP30fpsOV9712Omnivision
1MP30fpsNT99141Novatek
1.3MP22fpsAR0134/AR0135Aptina
1.3MP15fpsMT9M001Aptina
2MP12fpsMT9D111Aptina
3MP10fpsOV3640Aptina
5MP5fpsOV5640/OV5642Omnivision
9MP3fpsMT9N001Aptina
10MP3fpsMT9J001/MT9J003Aptina
14MP2fpsMT9F001/MT9F002Aptina
Video Demo
Documentations
Introduction to Arducam USB Camera Shields
1. Building a Camera System 1.1 The Difficulty of Connecting an Image Sensor to Your System If you have an adequate budget, the easiest way is to buy the off-the-shelf industrial camera and use it as is. But if you decide to design a camera using an image sensor from scratch, you will face the […]
Arducam USB2 Camera Shield DataSheet
Arducam USB2 Camera Shield User Guide
0
Your Cart is empty!
Browse Products
